has anyone ever put c4 sport vette seats in a thirdgen?
Old Jul 25, 2006 | 08:10 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I have a friend that has some c4 sport seats for his camaro. He was going to take his recaros out and put these seats in. Unfortunatly because they were both power and the floor pans arent at an equal height with eachother because of the cat converter hump. Thus one was higher than the other. We determined that the power on both sides needed to go because the seats sat really high.
We figured if we used the factory non power tracks with big spacers on the dr side to even the height out that it would work. But by that time we said forget it [wanting to get back to the LS1] and put the recaros back in.
Has anyone ever tried to put c4 seats in a thirdgen? If so did they make a list of things that must be done?
Speed
Old Jul 25, 2006 | 12:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No matter what seats you put in, your easiest way will be to modify the stock thirdgen seat tracks to fit to the new seats. As you discovered, the corvette seat tracks are designed to bolt to a flat floor, not the goofy thirdgen floor. The thirdgen & 4th gen brackets are already set up to deal with the floor. If the power brackets are too high, buy a used set of manual thirdgen brackets. I'm sure you can get them dirt cheap through the classifieds.
Old Jul 25, 2006 | 02:54 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If you need some manual racks, i have 2 in my garage.
Old Jul 25, 2006 | 03:02 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
anyone have pics of c4 seat in a camaro, because I think that would look pretty good, and comfortable I've rode in many a C4 and I love those seats
Old Jul 25, 2006 | 05:44 PM
Car: 1989 IROC-Z
Engine: 346 LS6
well... we did put the factory manual tracks on and found that they sat quite high, now for me... i was ok [but im 6'1"] but as for my friend [6'3"] it was a bit of a squeeze. But i guess a little lowering was in order. If it turns out that he doesnt want them i will try to install them and make them work, but until then thanks for posting guys.
speed
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Briandrex
Oct 5, 2015 06:20 AM
Gordonr1973
Sep 29, 2015 11:59 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
