Speedometer Needle
Old Mar 20, 2004 | 05:37 PM
1982Camaro383's Avatar
Speedometer Needle
Question for you guys I have a 1982 Camaro with a factory gauge cluster how do you remove the speedometer needle. I am taking the dash apart and looking at what needs to be done to install autometer gauges. What exactly is involved in installing the 5" speedometer, and 5" tachometer which will be installed where gas gauge is, 2 1/16 volt, water, oil. Anyone have any ideas or where I can find them.
Thanks,
Justin
1982 Camaro
Old Mar 20, 2004 | 05:58 PM
3gc's Avatar
3gc
Car: Z28
The needle just comes off but why would you want to take off the needle? The whole speedometer is removable, you need to first remove the guage cluster though.
Old Mar 20, 2004 | 06:48 PM
I removed the gas gauge, dash cover, lens, cluster all that is left is the speedo gauge, pulled on the needle and nothing dont want to break it taking it off.
Thanks,
Justin
1982 Camaro
Old Mar 20, 2004 | 07:43 PM
3gc's Avatar
3gc
Car: Z28
That's not the proper way of removing the cluster. Here, i just wrote this article for you. http://3gc.net/articles/interior/gauge_Cluster.shtml
Old Mar 20, 2004 | 09:48 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yep, that's the ticket. Just lower the column instead of trying to wrestle the cluster free.
1982 - the speedometer is removed from the cluster housing from the REAR. You need to remove the cluster housing (white part) to remove the speedometer assembly. The whole cluster (with all the gauges in it) should come out as one piece if done right, remove the trim panel held on with the torx screws, then remove the two 10mm speed nuts, detach the speedo cable and it just pulls out. Again, lower the column out of the way unless you like wrestling and slinging foul words around.
Old Jul 25, 2006 | 04:43 PM
theirlaw's Avatar
How do you remove the needle on the speedometer?
Old Jul 25, 2006 | 05:14 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Pull strait off, but I would not do that. The calibration will be off.
Old Jul 25, 2006 | 06:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The pics in the following link may be helpful:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
