4th gen interior swap/LT1 swap
Old Jul 29, 2006 | 03:03 PM
jjohnston's Avatar
Car: 91 Camaro RS
I didn't know weather to put this here or in the engine swap area...
I am doing the LT1 swap on my 3rd gen. I know I need to do some custom wiring to make the LT1 work with my factory setup. My question is, If I were to get the dash insterments etc out of the 4th gen to put in my 3rd gen car, would that make my wiring any different?
Old Jul 29, 2006 | 03:29 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
if you are dropping LT1, just use the harness with the LT1 and it would be easy no cutting wires just plug in the gauge cluster, head lights etc. Some things will still not work unless your car came with it like airbags, etc.
Old Jul 30, 2006 | 01:52 PM
jjohnston's Avatar
Car: 91 Camaro RS
someone sent me a message saying that it would be more work to get that to work, than just using the 3rd gen dash and the LT1. How is that possible? I'm no mechanic, so I am curious. because I need to get it done soon, and was hoping doing the dash swap would save me some headachs, then I would worry about the console later, like over the winter.
Old Jul 30, 2006 | 02:47 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i put a 2000 camaro dash in my car its not that hard. and i think its easier for the lt1 u dont need to cut and splice wires. just need to rig up the hot/cold cable for heater.
Old Jul 30, 2006 | 02:58 PM
jjohnston's Avatar
Car: 91 Camaro RS
cool, I don't have AC anymore so that won't be a huge thing to get done right away.
So what your saying is... It would most likely save me time in dealing with the wiring?
Old Jul 31, 2006 | 01:59 PM
Firebat's Avatar
I've done the LT1 swap and the Dash swap. I would treat them as 2 separate projects and wire them separately. I've shortened the LT1 interior harness a lot, mainly because I have ALL of the wires coming through the firewall on the drivers side, not on the drivers side AND the passenger side like on stock 4th gen cars. It all depends on how you run the wires through. I'm considering relocating the pcm to inside the car, behind the dash also, but that would mean adding about 4 feet of wire to 75 wires.
Old Aug 15, 2006 | 08:46 PM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
Would the steering column bolt up the same way
Because the 4th gens hadracapinions and the 3rd gens had steering gears
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
