Instructions to convert early third gen to rear shoulder belts
Old Jul 29, 2006 | 08:44 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
So after some searching I learned pre-89 third gens do not have shoulder belts in the rear. 89 and later can be a direct bolt-on for a 4th gen belt.
I drive and 86 and have the 4th gen parts but am looking for instructions and parts needed to get them to safely fit in my car so the kids can ride in the back once again (they used to when they were in 5-point harnesses).
Can anyone point me in the right direction? Is there a thread or tech article I missed?
Old Jul 29, 2006 | 09:34 PM
MNformula350's Avatar
I would assume you could get the mounts for the rear shoulder belts out of a 89-92 car, then weld them into your car in the same location. Then of course, get the appropriate plastics for them as well.
Old Aug 1, 2006 | 05:49 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I did this conversion on my 84 T/A this past spring. It was a pain in the butt. I cut the section around the mounting brackets out of a junk car and drilled out the spot welds to separate the bracket from the wheel well sheetmetal. The passenger side bracket sat nicely in place, but the drivers side wheel well is shaped a little bit differently on the earlier cars than the later cars. I had to make a 1" diameter indent for clearance. Also, the 4th gen retractors are a bit taller than the 3rd gen ones. That meant I had to heavily modify the drivers side bracket to lower it enough for the plastic pieces to fit properly. If you can, I suggest getting 3rd gen retractors to use. I think it'll make it a good bit easier.
Old Aug 6, 2006 | 08:36 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally Posted by JeremyNYR
...I had to heavily modify the drivers side bracket to lower it enough for the plastic pieces to fit properly. If you can, I suggest getting 3rd gen retractors to use. I think it'll make it a good bit easier.
I did the same conversion, but used 3rd gen retractors... same problem. Upon test-fitting the plastic, the retractor sat way too high. The only way to get the plastic to fit was to modify the wheelwell to let the bracket sit lower.
1992 Trans Am
May 10, 2023 07:19 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
bjpotter
Aug 12, 2015 06:06 PM
