82 83 84 bird pads vs 85-92 ones, difference?
Old Aug 2, 2006 | 07:55 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok i cant get a freaking straight answer out of anyone it seems
all i need to know is for sure if the 82 83 84 dash pads in the birds changed in 85 or not, or if all 82-92 pads are the same (in the birds)
yes, or no ?
if you dont know for SURE then please dont say anything
please!
im tired of getting both answers out of ppl
i could swear that we had it figured out on this forum that they are not the same pad after 84
but now its up in the air,
something about the vents changing or the speaker grilles changing
but would that prevent an 85 up pad from bolting into an 82 83 84 ?
yes?
no ?
thanks
Old Aug 2, 2006 | 09:33 AM
MavViper's Avatar
From what I have read the only difference between them is cosmetic, that a 85 pad will bolt up fine to a firebird from 82-84. It's just the look is a little different.
Old Aug 2, 2006 | 10:48 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
the pads bolt-ups are the same, the earlier birds had a cosmetic indent that ran the full length of the dash pad edge to match the trim on the door panels somewhat.. the newer ones are smooth on the dash edge.. the speaker grilles changed too, though the air vents did not.. so with a newer dash you need newer grilles and vice versa.
How do I know? I have owned and bolted up both. Currently have an 85 up pad in my 82 bird.
Old Aug 2, 2006 | 11:08 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I've got one from an 85 sitting right here (mint condition.. but no one wants to buy it lol) and it does NOT have the indent. If that helps.
Old Aug 2, 2006 | 01:37 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
awesome thanks, good info
cosmetic isues im not concerned with
i just am looking for one for my 82 and need one that will actually fit and work
dont care if its factory correct, as long as it doesnt have to be chopped to make it work
you know
hunter, how much for your pad you have ?
shipping from cali though
hmmmm...... oh boy..
i sent a pm anyways
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Vintageracer
Aug 11, 2015 08:13 PM
