power door locks
Old Aug 4, 2006 | 11:00 PM
mike d's Avatar
power door locks
another problem the buttons on the doors to lock or un lock you can hear the noise it makes like its working but the slides on the door panels dont move its a 1988 trans am.
Old Aug 4, 2006 | 11:08 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
I'm having the same problem except my door lock's slide in about half way
I think im just going to take the door panel off and lube and clean all the rods for the locks.
Old Aug 5, 2006 | 01:12 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
clean the tracks if that doesnt work take off the driver side kick panel and make sure the relay is screwed tightly to the frame. that's how they are grounded and they work their way loose over time causing lazy locks
Old Aug 5, 2006 | 04:45 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
My stereo guy is installing an Alarm system in my car and he says for an extra $20 he'll replace the door actuators with universal ones. I tell how well they work when it's completed.
Old Aug 5, 2006 | 05:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is a common problem. Clean and lube the tracks--do the windows while you're in there. Check the following link for more possibilities:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old May 12, 2008 | 04:48 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
Re: power door locks
To clean and lube the rods and tracks, what should be used? Like WD40 or a heavier grease? I know it's a simple question, but I'm just starting to learn to do these things myself.
Old May 12, 2008 | 04:58 PM
JamesC's Avatar
I used WD to thoroughly clean (along with some elbow grease) and white grease to lube.
JamesC
Old May 12, 2008 | 07:57 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Originally Posted by JamesC
I used WD to thorough clean (along with some elbow grease) and white grease to lube.
JamesC
WD-40 to clean and white lithium is good. Don't use silicone lubricants.
Old May 13, 2008 | 08:40 AM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
yea, you'd be surprised how a little oil goes a long way. my hood latch wasn't releasing, i put some oil in it, and now it works beautifully. also, this isn't relavant, but keep your door hinges oiled, it will help resist wear. just keep everything oiled up and it should work fine.
Old May 13, 2008 | 10:26 AM
eddie jr's Avatar
i am confused, what tracks are associated with the door locks? It is only the actuators and the connecting rods that go the the locks and handles.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
