Gauge Cluster Question?
Old Aug 5, 2006 | 11:26 PM
camaro of solar's Avatar
OK I did the DIY Gauge Overlays, and well its on a 92 RS with the electric calibrated gauges....and they are all fooked up now...anyone have any idea how i might aeable to fix what i cause din stupidity? will GM Recalibrate them?
Old Aug 8, 2006 | 03:21 AM
anyone?
Old Aug 8, 2006 | 04:59 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well since you "FOOKED" it all up you may just want to purchase a new or used gauge cluster
Old Aug 8, 2006 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A description of what's actually wrong with them might help.
Old Aug 9, 2006 | 05:25 PM
CamaroChick4Lif's Avatar
Car: 1987 Camaro Z28
Engine: 350 swap
Well if its anything like the gauges on my ex's neon. When I changed them the speedo, temp, fuel and all didnt work right. I ended up having to let the car run for a few minutes and get to normal temp with the cluster on but the clear cover off. I then took the needles off and adjusted them to where the norm should be with the temp gauge and fuel where it was when we turned the car off before the install. As far as the speedo I ended up driving it down the road and got someone to tell me when we were goin a certain speed and adjusted the speedo needle the same way. Takes a lil playing around with but it works. The speedo is only like 4mph over so its not bad. I think some places can recalibrate it for you but you will have to call and ask. Try this first and then if all else fails and nobody can recalibrate it for you then you will have to get a new cluster and say bye bye to the gauge overlays unless you can find someone to do it that knows how to install them properly. Good luck.
~Jeanna~
Old Sep 14, 2006 | 01:00 AM
awesome...imma give that a shot next chance i get...didnt think about doing that...and as for the recalibration...ill ask GM abotu that first and start form there...
Old Sep 14, 2006 | 08:41 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
so you pulled your needles off to but on face wow that sooked not me sliped them right over to avoid fooking them up like that
1991 Chevrolet Camaro - Rocky's Chevrolet
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
