gauge cluster questions
Old Aug 22, 2006 | 09:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
i have an 88 firebird. I did the V6 to V8 swap. i have a mechanical speedo and the cluster is electrical, obviously the tach doesnt work. my question is what can I do to get the stock gauges to work? Can I swap a mechanical speedo cluster system? maybe from an 87 V8 so i can make everything work?
What should i do, to make my 88 V6 cluster work? Or what can i sub in there to make it stock looking?
Old Aug 22, 2006 | 09:13 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
you have a mechanical speedo on an 88 firebird?
i thought everything after 87 was electronic, someone correct me if i'm worng
Old Aug 23, 2006 | 05:54 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I have a tranny with a mechanical speedo, my cluster is not. So I need to make one match another.
Old Aug 23, 2006 | 06:48 PM
johnnyboy's Avatar
oh, well then, get a mechanical speedo, tkae the electronic one out of the cluster and replace it with the mechanical, as long as you have the cable to hook it up you should be good to go. gm used the same plastic housing for all of the clusters as far as i can tell and there is still the hole in the back of the housing to connect the cable for the speedo.
Old Aug 23, 2006 | 08:59 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
i tried to use an 83 cluster in the 88 but it doesnt fit.
Old Aug 23, 2006 | 09:23 PM
johnnyboy's Avatar
did you try to use the electronic cluster with the mechanical speedo in place of the electronic one?
i mean remove the electronic speedo from its cluster and put the mechanical one in
Old Aug 23, 2006 | 09:24 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
if im readin this right
Get a electronic VSS for the tranny and since the 88 should have the wiring for it wire it up
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
