a/c and heater vent not switching from defrost to bi-level
Old Aug 29, 2006 | 09:45 PM
chad_89's Avatar
Car: 89 Camaro I ROC Z
Transmission: t5
iam havin a problem with my vent not switching from the defrost to the floor. it only blows out of the defrost vent , im not sure if its a vacume leak or what. if some one could help it would be very appreiciated thnks -chad-
Old Aug 29, 2006 | 09:48 PM
MNformula350's Avatar
Generally when that happens it is a vacuum issue, either a hose is, broken, cracked, off or pinched. The blowing out the defrost vents is the default in case of a failure.
Old Aug 29, 2006 | 10:01 PM
chad_89's Avatar
Transmission: t5
i hose like in the dash? or elsewhere
Old Aug 29, 2006 | 10:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You would need to pull the whole dash and diverter box under the dash in order to verify. Try replacing the AC panel first before you get into removing everything.
Old Aug 29, 2006 | 10:28 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I believe no vacuum = defroast only. Chances are the hose is cracked under the hood. Should run from the intake to a one-way check valve. It should then run into the inside of the car (and I believe a vacuum tank under the battery tray).
Check all those first before pulling the dash apart.
Kevin D.
Old Aug 29, 2006 | 10:38 PM
chad_89's Avatar
Transmission: t5
alright thanx every one!!!
Old Sep 4, 2006 | 08:54 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Pull out the control unit and look at the diaphragm on the back. Its where you have like 5-9 vacuum lines going in, looks like a wheel. Make sure the wheel isn't loose, that its snug against the rubber seal. I've seen a lot of failures on older GM vehicles from this.
diana227vegas
Jul 8, 2016 12:27 AM
Todd84Z
Sep 4, 2015 08:02 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Aug 29, 2015 11:08 AM
lakeffect2
Aug 23, 2015 08:44 AM
