installing seats
Old Aug 30, 2006 | 09:06 PM
newRSdriver's Avatar
Car: 90 RS
Engine: 305 TBI
Transmission: 5-speed
installing seats
Is it easy to install 4th gen seats in the 3rd gen car or will i have to make modifactions for it to fit right?
Old Aug 30, 2006 | 09:13 PM
zdc590's Avatar
Direct bolt on, dont worry about it, although i think theres a little extra space for the backseats, makes a small gap....i think. Nothing i would worry about though
Old Aug 30, 2006 | 09:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
all you need is a 13mm socket
Old Sep 2, 2006 | 11:45 PM
Car: 90 RS
Engine: 305 TBI
for the power seats....are there wires that run to the battery that i will hook up or does it run on batteries?
Old Sep 3, 2006 | 06:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the original passed through the fuse box. Find a wiring diagram--well, well, here's one:
http://www.geocities.com/vtcamaro/Pi...rams/pg252.jpg
JamesC
Old Sep 3, 2006 | 11:04 PM
Pocket's Avatar
Car: 91 Trans Am
Id use a 13mm box end and a 13mm socket with an 8-12" extension
The rear bolts on the front seats can get trickey
You need a boxend for the backseat, a socket wont fit under it
Should take you a max of 3 mins per seat to remove
Power seats on the otherhand:
#1 be sure you get the power seat wiring harness when you get them
They are hard to find sold separate
#2 All the power seats ive seen have 2 wires Power and Ground (orange and black)
#3 most 3rd gens do NOT have any provision for a powerseat so a wire under the carpet is unlikely if you havent already seen it
#4 when wiring the power seat pay attention to the wire size so you dont cause a potential fire
#5 Use a fuse!!!!! It doesnt have to be at the fuse box, inline works fine
Mine uses a small pitail of an enginebay fuse and has a handy lil cover
#6 Use a fuse thats close to the amp draw of the seats ie an 80amp fuse is a bad ideer
#7 Hide the freakin wires
#8 when cutting wires add a few inches of slack, no they dont stretch!
Old Sep 4, 2006 | 05:47 AM
JamesC's Avatar
They're plentiful around my area.
JamesC
Old Sep 4, 2006 | 12:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My RS didn't have power wire under the carpet - I just ran a wire with an inline fuse from the fusebox, under the door sill plastic, under the seatbelt cover, under the carpet, and up through a slit I cut in carpet under the seat. I cut the connector off the seat motor wire, and crimped female spade connectors there. Crimp a normal spade connector on both ends of the fusebox wire you ran, plug one into the seat motor connector, plug the other into an empty spot in the fusebox labelled "battery" - there are 3-4 empties in the fusebox. Then, run a ground wire, with a male spade crimped on the seat side, and crimp a screw-type connector on the other end - run it under the carpet, drill a small hole somewhere in the side of the lip that the door sill plastic covers, and insert screw for ground. I think I used a 15amp fuse inline.
The 4th gen seats don't have any split in the shoulder belt retainer to put your belts through - but if you look at various year 3rd gens, some came with retainers that were factory split, swap those onto the 4th gen seats and you can get your shoulder belts retained nicely.
On the rears, I had split rears originally, and the 4th gen rear was one piece - but the 4th gen rear covered the split seat posts in the middle pretty well, and otherwise fit right in.
NOTE!!! If you can get the 4th gen seatbelts as well, I recommend it! I swapped in a set of 3rd gen seat belt receivers with the recall fix (the silver tab in the receiver) - but those recalled receivers broke within a month of install as well! I'm swapping to the 4th gen belts - but the entire belt system has to be removed and replaced (receivers, retractors at seats, and retractors in ceiling). Another excuse to redo that sagging headliner too!
Old Sep 8, 2006 | 09:12 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
TTT
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
