Seat Belt Receivers
Old Sep 6, 2006 | 05:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Seat Belt Receivers
I understand they break. I understand that there was a recall on them, and that the recalled units have a silver tab in the top. I got a set of recalled receivers, with the metal tab in the top, and damned if they didn't break too! Within a month of install! The plastic inside broke, causing the button and the spring under it to go flying through the air.
Is it just my luck, or am I doing something wrong here? Simply push the red button, right? It isn't rocket science!
Can this be fixed in the existing receiver (ie a fix kit or something), or must I hunt down another set?
Old Sep 7, 2006 | 09:52 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I just used 4th gen seatbelt receivers in my car, the angle is more drastic, but they work when you put the seat back in the car.
Old Sep 7, 2006 | 04:34 PM
Car: 1992 RS
Engine: Carbed 350
You used 4th gen receivers with 3rd gen belts? My 3rd gen belts won't fit into the 4th gen receivers I have - the sizes are different and the belt clips won't insert in the 4th gen receivers.
It's a PITA - this was a 1992 car - the factory receivers should have had the problem corrected in the manufacturing, as the recall was in 1991 as I remember. I have 4th gen belts and receivers - just trying to avoid the install of them, as there is some modding to be done to get it to work properly and look nice.
Old Sep 7, 2006 | 04:36 PM
krisb410's Avatar
Yup, the receivers came out of a 02 Camaro, same car that I got the seats out of. Check out the picture in my vbgarage, I know the pic sucks and you can bearly see it, but it works.
Old Sep 7, 2006 | 05:07 PM
MNformula350's Avatar
I used Receivers from a 03 Cavalier, the housing is a lot thicker plastic, and more sturdy than the 3rd and 4th gen ones. And it was what I found in the color I wanted.
Old Sep 7, 2006 | 05:10 PM
Car: 1992 RS
Engine: Carbed 350
Those 03 receivers look really nice - and the 3rd gen belt fit in them as well?
Old Sep 7, 2006 | 05:11 PM
Yup, the factory 3rd Gen shoulder belt clicks right in, No Problem.
Oh, and my seats have been cleaned nicely since that pic LOL
Old Sep 7, 2006 | 05:33 PM
krisb410's Avatar
Here are my 3rd gen seatbelts with my 4th gen receivers
Old Sep 7, 2006 | 05:52 PM
Car: 1992 RS
Engine: Carbed 350
Thanks for the pic - just as I suspected - my seatbelts are different (wider and shorter), and that's why they won't fit into the 4th gen receivers.
RyanJB
May 7, 2016 06:23 PM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
