How can I make fiberlglass interior panels?
Old Oct 3, 2006 | 10:57 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
I want to replicate the plastic interior panels in the back using fiberglass or maybe make them slightly different. What would be the easiest way to do this? Could I just coat them in some so they dont stick, fiberglass right over them, seperate and sand it down or would I not be able to get them to fit right. I would do it in 3 pieces most likely, right, left, and the back piece. I dont think theres any cheap way of making a mold for them. I also would want to figure out a better way to mount them while I was at it probably.
Is it true that they sell a foam spray that I could just spray over the panels to make a mold and then use the molds to make the panels? As you can tell I havent had much experience with fiberglass but I know people who do.
Im not going for the ***** look, just something better than what I have now. I would end up painting them the same color as my louvers and GFX which is a charcoal. My seats and door panels are black and charcoal.
Old Oct 26, 2006 | 08:23 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Foam spray ? Of course, they got it at HomeDepot.
Old Oct 30, 2006 | 04:17 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Check these videos out: DVDs and Videos - Fibre Glast Developments. The guys also have everything you need to make whatever you want. Good luck.
Old Oct 30, 2006 | 07:58 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Let me know how it turns out. I was thinking doing something similar.
Old Oct 30, 2006 | 08:44 AM
MaineIrocer86's Avatar
Car: 1986 Z28
defiently post of some pics...if you do it!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
