Hatch not working...
Old Oct 4, 2006 | 07:47 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
OK, my hatch doesnt do ANYTHING. Turn the key, nothing. its in the "closed" position. ALL my fuses in my box are all good. No buzzing, no osunds. What can it be?
I dont know if it has any effect on it but the little plate that has 3 metal plates on it on both the underisde of the hatch and the interior plastic (right beside the latch motor) is missing on my hatch itself...will that make a differance???
Are there any relays or such i can check. I know this motors arent cheap. thanks.
Old Oct 4, 2006 | 08:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
mustangs on a thirdgen board? sad. anyway the metal plate on the hatch is i believe a switch, and if it not making contact with the hatch motor plate you could have a problem.
Old Oct 4, 2006 | 10:10 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
No, no, no. The metal plate 86TA is referring to has NOTHING whatsoever to do with the hatch pull-down motor. It powers the HMSL (high-mount stop light) from 1986-90. In fact if we're referring to his 1992 it won't even have such a contact pad at all since his HMSL is hard wired. First thing to check is that you have +12v at the red with white stripe wire.
Lon
Old Oct 5, 2006 | 05:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ahhh... so thats how the light works... thats good to know thanks!
Old Oct 5, 2006 | 08:39 PM
Transmission: T5/T5
Considering its NOT a bad thing to like more than one car...yeah.
Anyways, thats what I thought. I figured thats why my 3rd lamp doesnt work.
This is on my 89....I sold the 92 LONG ago.
So if it is getting 12v to the motor, does that mean the motor is bad or is there a relay? thanks.
Old Oct 6, 2006 | 04:40 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
it could just as easily be a bad switch inside the mechanism as the motor.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
