Door Panel removal
Old Oct 22, 2006 | 07:30 PM
83Chevy__Camaro's Avatar
Door Panel removal
i cant seem to get the door panels off the car, i read the shop manual but they dont seem to budge when you push them up and out or whatever, and i dont want to break them, help?
Old Oct 22, 2006 | 07:41 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
I'd like to know too. I took mine off yesterday & at the top of the panel (on the wood/cardboard part) underneath the black trim piece I ripped the every single mounting hole trying to pry it off. Does not really matter on these cause the panels are all warped & water damaged & I have to buy new ones anyway, but for the future I'd like to know THE RIGHT way to do it.
Old Oct 22, 2006 | 09:32 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
this is what worked for me...
roll the window all the way down & open the doors,take off the armrest & stuff, start from the bottom & work up popping the plastic screws out of the door, once the doorpanel is flopping & the only thing holding it on is the black plastic that runs along the top, hold the door panel with one hand, now start from above the door handle & going forward, hit the black plastic... that's right i said' hit it' (but not too hard) with your other hand, a quick thump with the bottom of your fist should do it, if this works the clips should pop off & the door panel will come off,
i've done this at least twice & it's worked both times
Old Oct 22, 2006 | 09:34 PM
do you mean just the panel or the black trim and the panel off as one piece, thats what im trying to do if get the panel and the black as one piece, as it is, cause its a lot easier to change stuff on teh inside then getting poked with those plastic screws while working in there.
Old Oct 25, 2006 | 02:26 PM
aperfectcircle's Avatar
Car: 91 Camaro
Transmission: 700 r4
Axle/Gears: stock, soon to change.
the panel and the black trim comes off in two different pieces its kind of a pain
Old Oct 25, 2006 | 11:05 PM
ok
care to explain? id appreciate it
Old Oct 26, 2006 | 12:12 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I use an air chisel, I've never broken a single plastic clip
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
