overhead console bulbs
Old Nov 10, 2006 | 04:22 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
i recently got hold of an overhead console. it was missing the bulbs for the map light and the flashlight. i was able to find the flashlight bulb at radio shack. they call it a flashlight lamp #243.
http://www.radioshack.com/product/in...rt&tab=summary
i am wondering if anyone knows where to get the bulb for the map light and what the part number would be. also i am not sure if the bulb would go into a socket or not. it looks like i may be missing another piece unless the bulb has the right connector. any help is greatly appreciated.
is something missing here?
here are the parts i already have.
Old Nov 10, 2006 | 05:00 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The lamp holder that your'e missing is similar to,but larger,the lamp holders used in the cluster and the shift indicator.Modern Day Muscle ( http://www.moderndaymuscle.com ) carries just what you need.Your'e also missing the lens for the lamp shell.When you get everything to put it back together line the outer lamp shell with some type of reflective tape(I used aluminum roofing tape).It will increase light output.
You have a very nice looking console.
Old Nov 10, 2006 | 05:41 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
you're right, modern day muscle does have it in their hardware section. thanks for the info!
Old Nov 12, 2006 | 10:49 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Your also missing the felt linings for the trim ring & map light.As well as the trim rubber piece that goes in the end of the map light(shell).As for the bulb it looks similar to the 194(dash,warning,Hvac,Side markers)bulb, but it has a larger head.The socket for the 194 lamps may fit the map light circut board!
Old Nov 12, 2006 | 11:37 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Looks like you picked up a great looking overhead console! Everyone above me answered all of your other questions. If you have trouble on the installation, let me know, my guide is up in the tech articles section.
Lbibb
May 5, 2016 12:00 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
MORREALE5
Sep 13, 2015 09:01 PM
