THE steering coloumn question
Old Nov 13, 2006 | 02:47 PM
Camaroreaper's Avatar
Right mates. i have a older camaro here and i want to swap into it the steering coloumn from a 94 transam. I has the radio support on it. and i would like to have that option on my car, Seeing as my grand cherokee has the much liked addition.
My question to you is;
"Can i put a 1994 Transams steering coloumn in my 84 Camaro and it fit?"
I will see this weekend regardless but im sure there is something i need to get before then. If anyone can help it would be appreciated.
Joey
I have the wiring harness from a 94 firebird allready in my car, to help the addition of a modified LT1. so all wiring should be fine.
Also if anyone wants to purchase anything related to f-bodys. Contact me
http://www.fbody.com/cgi-bin/partsfs...id=45699#45699
Im giving stuff away for free!!
Old Nov 13, 2006 | 02:54 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Joey
It kind of fits, but it doesnt work right.
Wiper blades dont work right. The module/switch inside the column that the lever pushes into is different. The 4th gen one has resistors inside it where the thirdgen one is just a basic on/off. Your wiper blades will only work when you are holding the washer fluid sprayer down. The turn signal cancels don't work correctly. I believe this is because the main shaft sits 90* where the 4th gen is at 45* or vise versa. This makes the turn signal cancel think the wheel is already turned 1/4 of a turn when its straight.
Some thirdgen columns had radio controls, maybe look into that.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
redmaroz
Aug 16, 2015 11:40 PM
