msd box with original tach
Old Nov 22, 2006 | 11:46 AM
chris75605's Avatar
Car: 84z28
Engine: 327
Transmission: t56
i just finished mynew engine for my 84z and im having problems with the tach. at first it didnt work but i bypassed some kind of filter or modual on the firewall and now it works but is off about 2000 rpm. i checked this with a aftermarket tach but i would like to keep the original if i can.
i never had the car running before now so i dont know if my tach is messed up or if there is something i need to do to make it read right with the msd box.
Old Nov 22, 2006 | 02:57 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You've run into a common problem with the factory tachs.There's either a capacitor or a resistor on the circuit board on the back of the tach that is the cause of the problem.My '83 had this problem when I got her. I replaced the tach and problem solved.A decent aftermarket tach will be more accurate but you want to keep her looking original.There have been many posts on this problem and there may even be a tech article on it.
If you have someone you can borrow thier tach to verify this is your problem.And the part you removed on the firewall is a filter for the tach.
Old Nov 25, 2006 | 04:00 PM
chris75605's Avatar
Car: 84z28
Engine: 327
Transmission: t56
thanks for the help
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
