Horn Question
Old Nov 22, 2006 | 06:52 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Horn Question
Whenever I Touch the wire to the wheel or metal it doesn't honk it just clicks. Now I know that the horn itself works I just can't get it to work inside the car. So what do you think is wrong with it?
Old Nov 23, 2006 | 08:19 PM
Firebat's Avatar
What you are hearing is the horn relay working. One or more of the wires going directly to the horn from the relay is(are) bad. Either the wire from the relay to the horn or the other wire going to the horn.
Use this schmatic for a reference(might not be exact but give you an idea:
http://www.geocities.com/vtcamaro/Pi...rams/pg217.jpg
The schematic might not be your exact year/model, so it might differ slightly.
The horn is located inside the front driver's side fender.
Or your horn could be bad.
Old Dec 5, 2006 | 08:23 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
my bet is your relay, sawp it with another one for test purposes and if the horn works then theres your prob. if not dive into the wires. just because the relay clicks dosnt mean its good.
Bubbajones_ya
Aug 31, 2015 12:02 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
redmaroz
Aug 16, 2015 11:40 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
