Center Console Top
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Center Console Top
I can't seem to get any type of dressing to adhere to it or my airbag cover. I used the magic eraser to clean them up a bit and strip off all the old armor all coats but, I switched to Black Magic and it seems like it won't ahere to the surface. It's glossy and then wet, then it dries and is a flat no shine surface.
I've even tried Armor All on it again and to no avail. Please help!
Car: 85 Z28
Engine: LG4 modified
You need to remove all traces of grease or oily substance. Try using white spirit. Test it on a piece of trim you can't see first though, as it can attack some plastics. Oh, and keep the windows open while you do it or you'll be high as a kite.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
