02 AluminumcVette Brake Pedal in a Camaro
Old Dec 12, 2006 | 08:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Yes,its a desperate attempt to make my car a little lighter.The vette pedal is 1.4 lbs,F-body is 2.7lbs.Besides this the geometry is pretty much the same.Main difference, vette part is slightly longer & the pedal pad is about 1 3/4 in lower.I will find out this weekend how/if it works out!
Old Dec 27, 2006 | 02:14 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
so how did it go?
Old Dec 27, 2006 | 03:27 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I got it installed, but as i suspected the pedal is a little low.Its about level with the gas pedal.So i removed it.I kept wanting to move the seat forward, beacuse my legs felt too short.It did work though & doesnt contact the floor when you mash the brakes.It needs a small plate welded to it so the brakelights are illuminated when you depress the pedal, but thats no biggie.Also the pin the hold the brake booster puh-rod is not included, but i also have the covered.Dont know what Im doing about the lower pedal though?Any suggestions
Old Dec 28, 2006 | 03:59 AM
911rsq's Avatar
Transmission: yes
the vette pedal is a cast aluminum piece isnt it?
Old Dec 28, 2006 | 12:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It looks like its cast, but i dont know if a cast piece would be strong enough for an application like this.I heard the suspension components were drop forged or something like that.Im guessing this is a similar item?Why do you ask?
Old Dec 30, 2006 | 01:55 AM
911rsq's Avatar
Transmission: yes
well, if it's forged, then you should be able to have it cut, shortened, then welded back together. you'd have a pretty trick piece then.... if it's cast, welding would be no fun at all on it...
Old Dec 30, 2006 | 03:46 AM
911rsq's Avatar
Transmission: yes
So this has been on my mind for the last hour and 45mins.....
Is that a brand new pedal you have, or a used one from a JY? If new, do you have the part number? I don't know why, but I have this sudden and overwhelming urge to make my car lose exactly 1.3lbs......
Old Dec 30, 2006 | 10:16 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
YES 1.3 lbs here 1.3 there.IT ALL ADS UP!I dont know if ill have it cut/welded.It more money than id like to spend, but ill find a way to get it to my liking eventually.
Old Dec 30, 2006 | 10:30 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
for that matter why not a fiero one? they had aluminum ones in certant years.
Old Dec 30, 2006 | 10:35 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Ive never noticed that in all the fieros Ive check in the J.Ks.Ill have to look closer from now on.
Old Jan 16, 2007 | 05:02 AM
911rsq's Avatar
Transmission: yes
i've sent questions to nearly every person that i've seen selling fiero pedals on ebay and they appear to all be aluminum....just thought u'd like to know...
Old Jan 16, 2007 | 07:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
This is good to know.Now ill be kicking myself for all the times ive passed by a fiero at the JK & not bothered looking below the dash Oh well live & learn.Another reason to go to the JK.Maybe the fireo pedal will fit with less mods required than the vette piece?Good info,Thanks.
Old Jan 16, 2007 | 07:32 PM
Pocket's Avatar
Car: 91 Trans Am
Ive owned 5 fieros over the years and non had alum pedals
Old Jan 16, 2007 | 07:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not that Im doubting you, but maybe these things are painted & they just look like a run of the mill pedal.I mean did you ever put a magnet or something to check what they were made of?Just trying to get as much information as possible.
Old Jan 17, 2007 | 12:40 AM
911rsq's Avatar
Transmission: yes
the one's that were on ebay were a grayish tan color and the tops of them where they connected and mounted were painted black. i have no doubt that they probably had steel pedals also, but the Al ones are going for CHEAP on ebay.......
Old Jan 17, 2007 | 07:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
What category did you look in?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
