Running gauge lines
Old Jan 2, 2007 | 02:29 PM
Clark's Avatar
Car: '88 IROC-Z
Transmission: 5-speed
Running gauge lines
I've got an Autogage mechanical water temp./oil press. gauge set mounted under the center dash vents. Only problem I have run into is running the lines through the dash/firewall. I know I should just run them through an existing hole in the firewall (one that wires go through, ect.), but don't have enough line to do that.
I would like to finish the install before 6pm tonight (MST), so If anyone has done this before and is willing to give me some help, it would be greatly appreciated! =)
Old Jan 2, 2007 | 03:27 PM
pairtoe's Avatar
i put in a water temp gauage recently, and i mounted the gauge next to my radio, and ran the line under the dash and through the firwall in the top right corner, and had just enough room. maybe an inch or two to spare. the only thing i can think of is if you drilled a new hole closer, but i would def try and find another way.
Old Jan 2, 2007 | 03:33 PM
Clark's Avatar
Car: '88 IROC-Z
I've seriously thought about that, but i don't think I have enough line on the to do that with the water temp gauge... I might have enough to run the oil like that, but i dunno...
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
