problems at the apulstry shop!!!
Old Jan 5, 2007 | 04:18 PM
ChevyRS-305's Avatar
i have had my camaro in the apulstry shop for about 4 months now and the guy finalyy started to put the suede in the car and started on the back panel peices which are white and he was going to glue them on but today i went in their and he showed me all he has done so far and to my luck the glue has soaked through the white suede. it look like crap and i was wondering what some of you(with exsperience in these things) think that can be done to have this suede on the panels. maybe a different glue or something or thicker backing on the suede. if anything we may haveto use white paint and die the panels white but i dont know how good that will look. so what do some of you think? hit me up thanks.
Old Jan 5, 2007 | 04:23 PM
firstfirebird's Avatar
3M makes a nice spray adhesive that I use all the time for multiple things (never suede though) and have never had a problem with bleading. It is a pressure sensitive glue and sprays on thin (both surfaces) and let dry for one minute minimum. Just don't make a mistake cause it isn't going to come off easily. It's readily available at Home Depot, but make sure you get the 3M 90 - it's $13 dollars a can but worth every penny.
Hope that helps
EDIT: This guy had your car for four months, and didn't even test a scrap first?! - Hope he's not expensive.
Old Jan 5, 2007 | 04:27 PM
well its not me doing none of the work its this guy and he is SUPPOSE to be a "profesional" he owns a shop and he does some nice work i just think he never has worked with suede b4 well not white because i also have blue suede too in the car and its fine no bleeding and yes he has used a scratch peice b4 but it turned out fine so i have no clue what the problem is and he is only chargine me $2300 for everything in my car to get suede...headliner, seats, dorr panels, A and B piller, hatch panel, dash, center counsle.
Old Jan 5, 2007 | 04:32 PM
Like I said, the glue should ALWAYS be tested on scrap first! I'm not an upholsterer, but when something needs to be done right the first time - test, test, then re-test.
IROCZ1989
Jan 24, 2016 03:55 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
FreeSpirit
Aug 29, 2015 05:47 PM
neekolzun
Aug 24, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
