Certain Interior Lights Wont Come On
Old Jan 7, 2007 | 12:55 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Ok folks,
My problem is this, there are a couple lights in my car that do not work, they stopped working after my battery was put back in after a recharge.
The following lights dont come on anymore:
The Shifter Plate Light - Already Replaced The Bulb, No Go
The HVAC Lights
The rear DEF switch light
The lights near my Driver Information Center (Digital Dash)
Fog Light switch
Headlight/Parking Light Switch
Do those last two switches even light up to begin with?
As I said, these lights stopped coming on after my newly charged battery was put back in, Ive checked all the fuses, they are all good.
EVERYTHING ELSE in the car works like it should, the dash dimmer wheel works, the dome lights, the cig. lighter, door chime, floor/courtesy lights, rear hatch light, they all work, all the switches work, they just dont light up.
PLEASE HELP ME!!! I have been trying to find the reason behind this for the past year, and have yet to find out WHAT needs to be replaced to fix my problem.
Would These Two Switches Have Anything To Do With This?
Old Jan 7, 2007 | 09:55 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
come on folks, SOMEONE HAS to know something!
Old Jan 7, 2007 | 11:56 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
Hmm
Get yourself a little cheap Multimeter from Home Depot or Lowes... then goes at it man. Start Troubleshooting power too the pins and the wires going too these locations. I'm sure you've checked all your fuses right? Just dig in.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
