82 different das pad
Old Jan 18, 2007 | 08:25 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
ok, i know this is going too start a big post, lol--i need to get a good used dash pad for my 82 Z, OR one of thos pads ??? --everyone says 82-92 fit, but actually the 82 z was different.--as your sitting in seat and look at the dash edge, the 82 dash had squared off edges or corners, and newer ones 83 up ?, had the more smooth out edges,----can i only find the smooth ones, and or cap ??? and are thos caps or covers any good.
Old Jan 18, 2007 | 11:15 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the covers are junk
the 82 83 84 pads are different from 85-up yes
good luck
Old Jan 20, 2007 | 11:03 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I agree with Fast68 on the years.The original dash pad in my '83 was more angular cut than the one I replaced it with.And it had a ridge around the edge similar to the one on the edges of the console lid.The dash pads will interchange up to '90.I believe the dash pad was changed with gauge pod change(but I could be mistaken on this).If you think of getting one off Ebay make sure and ask the seller that it's a Camaro dash pad and not out of a Firebird.Also if there was a change in the '91-'92 dash pads what year it's out of.Good luck in your search.
Old Jan 20, 2007 | 01:09 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Camaro and Firebird dashpads are NOT interchangable. However, all 82-92 Camaro dashpads are interchangable and all 82-92 Firebird dashpads are interchangeable. 1982 Camaro dashpads are different but you can use the later style. (I've heard some '83's may have come with the '82 style pad as well.) 1982-1984 Firebirds used a different style pad from later cars but later pads will fit too.
Old Jan 21, 2007 | 09:11 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
All 82 and 83 dash pads are the same. 84 was the first year for the new style.
Old Jan 25, 2007 | 07:09 AM
seymourless's Avatar
yea i found out the hard way about the dash compatibility lol. i got one off ebay, but the seller did not specify if it was a camaro or a firebird. got it at the house with a crack in it from poor packing and it turned out to be a firebird dash, which didnt fit my camaro. the width of the firebird dash was fine, but the length from the glass to the wheel was an inch to short. I liked the speaker grill though, looked more in place compared to the camaros random slots in the dash
Old Mar 22, 2007 | 09:28 AM
Ymesss's Avatar
Car: 1986 Camaro Z-28
Re: 82 different das pad
Sorry to bring up an old thread but anyone know where you can buy this style new, the 82-83 pads? Im i basicly screwed and need to grab one from a yard, because as you prob all know pads arnt easy to find let along within those years?
Vintageracer
Sep 24, 2017 12:34 PM
86IROC112
Nov 7, 2015 06:50 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
