Auto dim miror wiring-help!
Old Jan 20, 2007 | 11:07 PM
philcol's Avatar
Picked up an auto dim mirror for my 87
gta. Car did not come with this option so how do I wire it up? It has three wires. One to ground and the other two go where? Can both be 12 volts? Can I use the overhead console wiring to power this?
Phil
Old Jan 20, 2007 | 11:20 PM
philcol's Avatar
OK, so is this correct?
Blk. - ground
Red - pos. switched
Green - For cancelling hooked to reverse light. What's this for?
Is there a reason the reverse wire has to be hooked up? Can I just skip it?
Phil
Old Jan 21, 2007 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might try a search as this question is one that pops up from time to time.
JamesC
Old Jan 21, 2007 | 09:08 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
If the mirror is auto dimmed, when putting the car in reverse, the mirror normals itself so you can see to back up if using the mirror.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
