headlamp help
Old Jan 31, 2007 | 11:42 AM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
headlamp help
ok hello here is my problim my headlamp switch in my camaro the plastick bolt that is black and has the rod going thrught it has broks now my switch is lose i have been to the junk yeard and tryed to get 1 off of a nother camaro but it in a tight spot and u can use your fingers to get it out is the a trick to this i am missing ??????????
Old Jan 31, 2007 | 12:03 PM
Gramps's Avatar
Car: 87 Camaro IROC
it has to be pushed back before it can come out. you take off the little nub, then push it back and remove the clips to get the cover off, then you pull it out and disconnect it and your free. at least thats how i remember doing mine.
Old Jan 31, 2007 | 01:16 PM
Engine: 305 tbi
i do not see a clip just a black bolt with the rd going thrught it anf i think its screed on but it it to tight to turn with your hand in that little spot and it u use tolls like plyers it tars up the bolt and it is hard to even use those
Old Jan 31, 2007 | 06:01 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Remove the hush panel below the dash. Look up at the headlight switch from below with a flashlight. There is a button that needs to be pressed with a screwdriver while you're pulling on the **** to release it.
Lon
Old Jan 31, 2007 | 06:08 PM
Engine: 305 tbi
so that will make it so i can un screw the black bot that holds it to the dash?
Old Jan 31, 2007 | 11:03 PM
lonsal's Avatar
Are you trying to replace the entire switch or just remove the **** to pull off the dash trim panel? I gave you instructions for removing and replacing just the ****. Sorry, I haven't replaced the switch yet. I'm sure it is covered in your 1986 Camaro Service Manual which you bought from www.helminc.com or eBay.
Lon
F-body-fan
May 4, 2026 09:42 AM
327IROC85
Sep 23, 2015 12:11 AM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
moodude
Mar 13, 2004 01:35 AM
KRUSS
Aftermarket Product Review
Sep 5, 2002 02:21 AM
