Switches but no power windows?
Old Feb 3, 2007 | 11:49 PM
element6968's Avatar
Engine: 305 TPI LB9
Hi,
In my 88 trans am, on my center counsole I have 2 power window switches, but I have manual windows, I have changed all the fuses but these switches dont do ANYTHING ,weird?
Iv searched but found nothing, can anyone explain this to me??
thanks,
Element.
Old Feb 4, 2007 | 12:12 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Maybe the center console has been replaced at sometime.
Old Feb 4, 2007 | 12:27 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
either your doors or center console were replaced/ modified
Old Feb 4, 2007 | 12:44 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
One, or the other, but not both.
You say you have manual windows...that means you probably dont have electric window motors, so of course, the switches dont do anything.
Id say the most likely scenario is that your console has been replaced by one that has power window switches in it.
Old Feb 4, 2007 | 02:08 PM
Engine: 305 TPI LB9
Thanks for the fast responces everyone.
Its just my luck that it would be a replaced console
Im going to pop off the door panel to see whats going on here.
Thanks again,
Element.
Old Feb 4, 2007 | 02:58 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
well if the doors have cranks, they don't have a power window assembly. You won't learn anything from removing your door panels. You'd be better off removing your shifter plate and seeing if there are wiring harnesses in there that would attach to the switches. If the wiring isn't there, your car almost certainly had it's shifter plate replaced and was originally built with manual windows. If the wiring is there, odds are the doors were replaced.
Old Feb 4, 2007 | 06:00 PM
Engine: 305 TPI LB9
Sure enough, theres a wire harness, the switches are all soldered up and everything.
Only my luck lol
Any way to tell the door are original? VINs on doors?
Old Feb 4, 2007 | 06:41 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
One thing for sure your car didn't come wired for electric windows but have manual windows also. Check the RPO codes. Only thing is they are usually posted in the center console and if it's not the original. Well guess what, they probably aren’t for your car anyway.
Old Feb 5, 2007 | 11:46 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
There is your vin number on the driver side door that should match your vin tag on the dash. But in your case it's probably wrong.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
