Speedometer gauge not working?
Old Feb 25, 2007 | 01:33 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
All my other gauges work fine, but my speedometer gauge doesn't? Any ideas why? I'm hoping this is an easy fix & doesn't require any harness work?
Old Feb 25, 2007 | 09:58 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Check out the cable, pull both ends off and look to see iif there is a bundled up wadded mess at either end, if so replace the cable. Also if the cable is ok then check the transmission gear to make sure it is not stripped. If all of that is ok then it is in the speedo head itself.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Jk_Under
Aug 17, 2015 03:08 PM
ChevyZ71
Aug 13, 2015 07:30 AM
