Interior drooping
Old Mar 28, 2007 | 06:38 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Interior drooping
Is there a tutorial on this site to explain how to fix headliner drooping? My Camaro has gotten pretty bad, once a little pocket started it kept progressing until most of it sags down.. any help would be appriciated.. thanks
Old Mar 28, 2007 | 06:42 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Re: Interior drooping
The only way to fix it is to recover it with new material or buy a new headliner. I just recovered my headliner, sail panels, and sunvisors and it cost me between $50-$60 for the materials needed.
If you want me to give a description on how to remove the headliner and recover, let me know.
Old Mar 28, 2007 | 07:44 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Once it starts falling down, the only repair is to replace it.
Old Mar 28, 2007 | 09:10 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Sure, I will tell you how to fix it, send me a $100 to my paypal and it is as good as fixed
Old Mar 29, 2007 | 12:31 AM
Kandied91z's Avatar
quick fix to get it looking somewhat respectible is to pick up some 3m spray adhesive or something similar. try to spray as little as possible into the area if you can reach of course and smooth the material out as best you can. it will look like hell but better then a fallen headliner.
if the liner board is broken and falling apart you need to pull it down and fix it. this isn't difficult but it takes some common knowledge of how things work. you could be cheap and use cardboard to back it or anything else that's thin and stiff.
material to replace is cheap. roughly $20 in supplies and a few hours of your time you should be able to fix your headliner. i've done 2in the last week after spending $100 on one at a shop to be redone. do it yourself or at least try...
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
