floor pans
Old Apr 1, 2007 | 06:17 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Axle/Gears: stock 10 bolt
floor pans
wasnt really sure were to post this but was wondering if anyone knew if it was possible to get the section of floor pan that goes under the drivers feet. Ive been looking and all i can find is the full length ones for like $250 a side. which i know i can buy and chop them down but would just like to save some money and get just the sections i need.
Old Apr 1, 2007 | 07:27 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: floor pans
nope, nobody makes just that part. the only place you can get the floors at all is from yearone i think. but you probably knew that. your best bet would be to post an ad in the parts wanted section of the classifieds i'm sure there is someone willing to cut a floor out of their parts car.
Old Apr 1, 2007 | 08:18 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Re: floor pans
ok, thanks for the help, i will more than likely do that than seeing how there so expensive.
Old Apr 2, 2007 | 10:39 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: floor pans
no i have the exact same problem all the rust is in front of the drivers seat they are on eBay for like 189 or something like that look hard they are there I'm gonna go to some junk yards and try my luck with a battery powered grinder saws all and drill for those spot welds youll find a clean enough one eventually that way
Old Apr 5, 2007 | 12:26 AM
Kandied91z's Avatar
Re: floor pans
$250 for a full side factory correct floor pan isn't that bad, shops charge that much to patch holes let alone replace a complete floor pan. if you have welding knowledge cut your own patch of metal or spend the little extra money. so many of these cars have shot floor pans from abused owners that to have one with good floor pans they are well worth the $500 you'll spend to do it right the first time.
if you plan to keep your car do it right the first time, if this is just a cover up to sell your car patch it up.
Old Apr 5, 2007 | 09:30 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Re: floor pans
ya i been thinking about it and i think im just going to do it the right way and spend the money and replace both sides. thanks for the help.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
