Steering Column Swap in an 89 firebird
Old Apr 2, 2007 | 01:20 AM
kauffmannl56's Avatar
Car: 89 firebird
Engine: 2.8 soon swapped 2 a 383 stroker
I am currently in a bind with my steering column. I took it apart to fix the common slack problem that is solved by tightening the 4 torx bolts. As I was doing so the bearing that goes around the shaft started to fall to pieces. The ball bearings were all over. I would like to know if this is replaceable or if I should swap the column. If swapping the column is the easier option then how would I do so, and what columns would fit. I don't have cruise, or radio options, no airbag, but have titlt. Any help in the matter would be helpfull.
Old Apr 5, 2007 | 10:17 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Axle/Gears: stock 10 bolt
Re: Steering Column Swap in an 89 firebird
hope you dont mind but i too have this problem and am trying to find out what columns fit what years. when i search on ebay for columns most people have theres listed for 82-92 but then some people have 84-88 for the years so im not really sure.
Old Apr 5, 2007 | 10:42 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
https://www.thirdgen.org/forums/susp...part-help.html
they are replaceable. look at freestylzz post, that might be the ones you want.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
