automatic shift knob
Old Apr 1, 2007 | 10:57 PM
88ta327's Avatar
automatic shift ****
how do i take the shift **** off of an 88 firebird and an 85 camaro.
Old Apr 1, 2007 | 11:14 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Re: automatic shift ****
On the Camaro you have to pull the button out of the ****. Look down the hole, there is a little ring that holds it on.
On the Firebird, there should be a piece of metal shaped like a staple on the side of the **** that faces the dash. Just pry it out with a screwdriver and the **** will pull right off.
Old Apr 2, 2007 | 12:02 AM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Transmission: Automatic
My 90 camaro has the staple. I forget the name of it, but ya just pry is out and pull up.
Old Apr 2, 2007 | 08:32 PM
Jay87Z's Avatar
Transmission: M6
My 87 Camaro has the staple, my 85 Camaro has the ring. The shift ***** are different as well. The 85 has a ball, where the 87's is like the one in your 90. I think it was 87 where they switched to the different ****.
Old Apr 2, 2007 | 10:53 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
i lost my staple somewhere in the dashdoard vents
Old Apr 2, 2007 | 11:00 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
A replacement staple is not hard to find/make. Just a piece of metal to look the **** in place, unless you go after market, then you shouldn't need the staple...
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
Night rider327
Feb 25, 2016 09:50 AM
loud91rs
Oct 5, 2015 10:05 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
