what's up with IROC horn buttons?
Old Apr 7, 2007 | 11:25 PM
RyanFromSC's Avatar
Car: 1990 RS
Engine: 305 tbi
Axle/Gears: 10-bolt 2.73 open
ok so my horn button fell off on my 88 IROC, for no reason. my brother's did the same on his 89 IROC, while he was driving! I've seen other people have this problem...so what's the deal? are they defective? j/w. Thanks.
Old Apr 8, 2007 | 04:50 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: what's up with IROC horn buttons?
This happened on an 89RS donor car that I used to have. I think there might be tabs that lock into the steering wheel. Check for those.
Old Apr 8, 2007 | 06:55 PM
iroc88lb9's Avatar
with age these cars just fall apart...they were very poorly made.
Old Apr 8, 2007 | 10:17 PM
I wouldn't go so far as to say that. I mean, the car is 20 years old. Plastic parts are expected to break/crack and or fall off after that long from standard use.
Old Apr 8, 2007 | 10:26 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
no it is fair to say that they were poorly made.
Old Apr 8, 2007 | 10:48 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Yes definitly, compare your car to other cars with the same milage at the same year. They all age the same, glue is glue, plastic is plastic.
Both of my 88's were in great shape, hell my new IROC has 75,000 orig miles and doesnt have a spot of rust. Minus the rip in the seats, the interior is mint and all the power options work..
It's 19 years old... Garbage? I think not.
Old Apr 11, 2007 | 12:40 AM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
NO!
i love my car even though stuff keep brakin .........
Old Apr 11, 2007 | 03:30 AM
iroc88lb9's Avatar
did i ever say i dont like my car? ive had quite a few of these 3rd gens,moreso then most have anyways.
you cannot deny the fact that these cars were poorly made,its just a fact,if you cant admit that,your simply in denial.
they were built with horribly weak drivetrains,problematic FI systems,and more quirks then i care to even debate over.
simple fact is,if they werent such good looking vehicles,NOBODY would tolerate the BS you have to deal with,with owning these vehicles.
my iroc is also an 88,with lower miles then your's,and it was owned by an OLD couple,and it has its fair share of problems.
the only reason i purchased MY iroc,was because it has ZERO options{less **** to go wrong with it}
and while most power options do continnue to work on these cars,they work so horribly,they might as well not even be considered power options,but rather time wasting anoyances. the windows move like mollasses in january,the locks work sometimes,sometimes they dont....vice versa.
i wont even get into how they run inconsistently on a day to day basis...
Old Apr 11, 2007 | 03:45 AM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
cheese pwnz m3
Old Apr 11, 2007 | 04:27 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I rebuilt mine by drilling and tapping threads in the plastic posts and using "Weld ON" epoxy to fix everything else that needed fixing. I used liquid shoe polish to brighten it up. It now looks and works like new. Cost $5.00.
Or
Modern Day Muscle has them for about $58.00.
http://www.moderndaymuscle.com/interior1?b=1
5spdcamaro
Aug 28, 2015 02:12 AM
Stauf
Aug 24, 2015 08:31 PM
smooth
Aug 18, 2015 06:34 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
