tach install help
Old Apr 16, 2007 | 09:45 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
tach install help
im buying a 5" tach...how do i install it, how hard is it?....what wires do i connect?....pictures would be helpful
thanks a bunch
Old Apr 17, 2007 | 08:21 AM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
Re: tach install help
Alright, the wires coming off the back of the tach are green, red, white, and black. black and white wires connect to your lights, just find a = and - that gets power when the lights are on. The red wire will connect to a switch(key on) power supplie. they make some nifty little connectors that would make the part nice and easy. one side you just slid over the wire your connecting to, and the other side you put in the wire your connection. dont know what they are called. the green wire will connect to the tach wire off the dizzy, its white. You will need the converter or some kinda of msd, mallory, accel box to give it the right signal. I would post some pics, but im in Austin tx, and my camara is in Houston. If you have any more questions let me know.. J
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
