b&m questions
Old Apr 12, 2007 | 06:40 PM
DillonRager's Avatar
b&m questions
i searched this but all it brings up are pics of the shifter fully installed.
i need to know if the red cable serves a different purpose than the stock cable besides the different ways to connect to the shifters. if i found a way (i have found a way) to hook up the stock cable to the megashifter would it still work the same way with out damaging anything(transmission)??
also wondering if anyone has instructions (i bought mine used) that they could explain to me or fax to me and maybe any install pics from above and below. thanks a lot in advance!!!
nevermind i found the instructions on the bm site but pics woould be good
Old Apr 12, 2007 | 08:31 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: b&m questions
I used the stock cable with my B&M Megashifter in my 89 and had no problems.
Old Apr 12, 2007 | 10:28 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
Re: b&m questions
y not just us the cable that came with the kit? its stonger then stock, and it not hard to put in.... its a good replacement for your old one which could break from all the ratchet shifting ull b doing with your new shifter... but idk it will work both ways so its up 2 u...
Old Apr 12, 2007 | 10:57 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: b&m questions
actually the one that comes with the shifter is hit or miss. I installed mine exactly as I was supposed to and it ended up getting detroyed after about 3 months. Quite a few people have had the same issue. Was SOOOOOO not fun backing out of my girlfriends driveway into traffic and having to climb under the car to pop it into drive while she was on the brake.
I got the heavy duty replacement cable which seemed better constructed.
I ended up selling it and going to the T56 so I am not sure how long that lasted.
Old Apr 13, 2007 | 11:26 AM
joshk879's Avatar
Car: Looking for a project
Re: b&m questions
I had the same issue with b&m's cable as well. I don't think it lasted me one summer before it broke. Its not too hard to replace though.
Old Apr 13, 2007 | 12:54 PM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
Re: b&m questions
how did yall go about installing the stock cable with it? I would like to know, cause i also bought a used one, and dont have all the peices to hook up thier cable to the tranny. Post up some pics if you could, i can't access my email. Thanks J
Old Apr 13, 2007 | 01:00 PM
Re: b&m questions
im going to cut the metal piece with the hole in it where the cable mounts from the stockshifter and cut the new one off as well then weld the old tab to the new shifter unless some one has a better way of doing this?
Old Apr 15, 2007 | 02:20 PM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
Re: b&m questions
I just tried to use my stock cable, and it doesn't seem to be long enough. How are yall using it???
Old Apr 15, 2007 | 04:52 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: b&m questions
Oh man pictures PLEASE............I am still having trouble getting mine to go thru all the gears right..I can either get to go into park, and not 1st, or 1st, and not park.........Most frustrating.I would put the stock cable back on in a flash, if it would help......Thanks, Tom
Old Apr 15, 2007 | 09:29 PM
Re: b&m questions
well im not sure what im going to do yet but if i go the stock cable route ill post pics definatley
Old Apr 16, 2007 | 07:56 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: b&m questions
Thanks, this thing has been a real PITA..........
Old Apr 17, 2007 | 11:15 AM
joshk879's Avatar
Re: b&m questions
i never used the stock cable, i just meant that the b&m ones are iffy. After mine broke i just replaced it with another b&m cable.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
