another question
Old Apr 22, 2007 | 12:13 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
another question
sorry I have all these questions but on a scale of 1 to 10 I am like a 2 when it comes to being mechanically inclined.
But theres a plastic piece that runs across the roof just above the rear passengers heads in my 1985 TA, and when it rains hard or I wash my Trans Am, water drips in on the ends.
Is the trunk weather stripping bad? I ordered some but I thought I'd ask here if anyone has any other ideas of where the water is leaking in?
Old Apr 22, 2007 | 12:19 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: another question
Is the car solid roofed or does it have T-tops. If t-tops, It could be them, but it's most likely to be the hatch seal.
Old Apr 22, 2007 | 12:21 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
they are t tops but I replaced the weatherstripping on them and Im not 100% sure without looking but the plastic piece that runs horizontal on the roof is back further from the t tops.
Old Apr 22, 2007 | 12:25 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Yes, but if the t-top seals are leaking, water will run along the metal and drop off at the lowest point...which in this case is that rear horizontal piece. You probably should just remove that plastic piece, its only a few screws, and run water on the top of the car and see where it comes in.
Old Apr 22, 2007 | 12:29 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Hmm I'll have to try that out... I did replace all the t top weatherstripping and seals, so if the trunk weatherstrip dosen't fix it I'll try that next...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
