steering wheel issue
Old Apr 26, 2007 | 12:22 PM
JohnSjr's Avatar
some explaining here:
the steering wheel isnt locked in place ( refering to the tilt function )
no matter what position i place the steering wheel into i can lift it upwards and it literally "jiggles".
when i am driving its fine due to where my hand is normally.
but i feel insecure in the fact its moving sometimes.
almost seems like there is a rivit or pin missing.
i really need some suggestions
( and a steering wheel diagram blowup if possible )
i have a feeling that theres something that may have snapped or broken loose inside the column.
car runs fine, steers fine but that wiggle which is almost a full 1 1/2" lift really is bothering me.
Old Apr 26, 2007 | 01:40 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: steering wheel issue
There are 4 bolts that usually come loose and cause the wheel to move just below the tilt pivot. very common problem. I don't have my manuals available now but I do know there are threads that cover this pretty well.
for tilt wheel pivot bolts you should be able to find what you need.
https://www.thirdgen.org/steeringcolumn
Old Apr 27, 2007 | 05:42 AM
JohnSjr's Avatar
thx for the info..
seems ill be doing this on saturday then.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
