Seat Foam
Old May 15, 2007 | 12:38 AM
JDennington's Avatar
Car: 91 RS T-Top
Engine: L03 [5.0 (305) TBI]
Transmission: MD8 (700R4)
Axle/Gears: GU2 (2.73 non posi)
Seat Foam
I want to restore the seats in my 91 anyone know where I can get new seat foam? Also I want to get rid of my stock steering wheel and replace it with a Grant is there a way to do that with out the infl rest light coming on? Thanks in advance.
-JD
Old May 15, 2007 | 01:04 AM
Car: 91 RS T-Top
Re: Seat Foam
....I know there are thousands of posts in here about removal of the airbag but what I was wondering was if there was a way to remove the airbag without the light coming on at all. For example the same way VATS is bypassed by using a resistor matched to the value of the resistance in the pellet in your key. I was thinking about removing the airbag and measuring its resistance in ohms and putting a resistor in line tricking the computer in to thinking that the airbag is there and everything is ok. Any thoughts?
-JD
(sorry about the double post)
Old Jun 5, 2007 | 10:21 PM
luke84's Avatar
Car: 1984 z28
Engine: 355
Re: Seat Foam
did you ever find a place to get seat foam? I need some really bad!! recovering my seats and foam is shot!
Old Jun 6, 2007 | 07:16 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Seat Foam
...air bag removal.. warning light display.
Disconnect the battery. Remove the panels for access to the underside of the steering column. Disconnect the yellow ars splice (wires to the air bag).
Remove the headlight switch stud by depressing the small release button on the underside of the headlight switch. Tilt and lower the steering wheel then remove the cluster trim ring. Remove the cluster. Remove the ars light bulb. Put it all back together. Then, remove the air bag and steering wheel.
Replace the steering wheel with your selection.
Old Jun 6, 2007 | 07:52 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Re: Seat Foam
hi, i have replaced my drivers seat foam on both my camaros with a passenger seat from a junkyard,also you can switch the material around too,it`s not that bad just go slow and it`s pretty easy. Both my seats look awesome. If you dcide too do that let me know i will help you out
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
