How do you remove front dashboard panel? 1991 Z28 Convertible.
Old May 16, 2007 | 06:51 PM
fatsamatsa's Avatar
Car: 1991 Z8 vert
Transmission: AT
Hey guys,
I am new to this forum and this is my first thread. I want to repair or replace my cigarette lighter socket, but i don't know how to remove the panel that sorrounds it. It seems like I can pull it off as if it is snapped in, but I am scared I am gonna hear snap crackle pop if i pull too hard. I searched online and even looked in the Haynes manual but they only show the removal of the dash that was on till 1990. If anyone has any idea i would be much obliged. Thanks.
Old May 16, 2007 | 07:47 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: How do you remove front dashboard panel? 1991 Z28 Convertible.
To replace the cig lighter, you need to remove the gauge trim. I assume that's what you mean. If so, it's easy as sin to remove. First, under the underdash panel on the driver's side, you will find 2 large torx screws. Remove those, and the ones along the bottom of that panel. That will remove the underdash panel. Next, you will see that under that, there were two little hex head screws holding the gauge trim on. remove those. Next, reach up behind the headlight switch and you will feel a little button on it. Push it in, and pull out the **** you pull to turn the lights on (you may hafta juggle it a little.) Then, pull on the gauge trim and the clips holding it will disengage and it will come out. Unplug any wires for any switches you have on it and there you go. Oh, and it may help to lower the tilt wheel a little to make it easier to snake out.
Old May 16, 2007 | 08:11 PM
fatsamatsa's Avatar
Car: 1991 Z8 vert
Transmission: AT
thanks for the tip...I am going to work on it this weekend...If i screw it up up i'll ask for more help...thanks again...
-by the way this forum rocks...I bought my vert last year on ebay and i am loving cruizin with it and i just signed up on this forum and already i have learned a ton about my vert...especially how to temporarily put the top up if the switch goes bad...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
