Auto shifter change
Old May 18, 2007 | 07:45 PM
Mokilok's Avatar
Car: 91 Bird
Engine: V6
Auto shifter change
How does one go about changing the shifter handle on an automatic?
Old May 18, 2007 | 07:59 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Re: Auto shifter change
Get a flathead screwdriver and pop out the clip in front of the **** (facing the stereo). Easiest to do this while the car is in low gear (so you have more room), then put it in park and slide it off......if it does not slide off easy (another thread) try to wiggle it back and forth while pulling on it.
Old May 18, 2007 | 08:58 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Killer klown is absoluely correct.
If you want a cheap factory looking t-handle. Get a shift handle for a 89-90 cavailer Z24 and slide it on. Works great..............
Old May 18, 2007 | 09:07 PM
Mokilok's Avatar
Car: 91 Bird
Engine: V6
cheap factory handle is what I have. Im lookin to upgrade. I wasnt sure if the release button was going to be a problem. Iv never taken one apart b4 and I have no idea how it goes together.
Old May 19, 2007 | 12:10 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
nope pretty simple to remove, I popped the c-clip and up it went, then installed my aftermarket...
Old May 19, 2007 | 06:45 AM
Mokilok's Avatar
Car: 91 Bird
Engine: V6
That was easy. Thanks fellaz.
camaro11j
Sep 19, 2018 08:49 AM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
jbd1969
Aug 17, 2015 07:06 PM
