shifter knob sticky/stuck
Old May 31, 2007 | 11:19 AM
Zachnoel's Avatar
shifter **** sticky/stuck
does anyone know if there is a spring that will push the **** back up? mine is starting to stick down when i put it back in park. maybe i have to lube it up? if so where? thanks
Old May 31, 2007 | 11:27 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: shifter **** sticky/stuck
Never had that kind of problem, but one would think it would be pretty simple to repair.
Take the shifter out, than pull the plastic piece inside the shaft and use a magnet to pull the spring out. I think thats how it would work.
If everything else fails use a hammer.
J/K
Good luck
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
