What seats do I need?
Old Jun 19, 2007 | 01:27 AM
dolphan7's Avatar
I have an 86 Firebird TA with no rear seats. That is the way I bought it. In shopping for a set of rear seats I find that there are split seats and bench, but the split seats come in both the seat back and the floor cushion both having a split. How can I tell which ones fit my car?
Old Jun 19, 2007 | 08:11 AM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: What seats do I need?
all thirdgen rear seats have a split in the bottom. To see whether you need a split rear or not, check the pins that the rear latches to. they're just in front of the wheel wells and look like the pin that the door latches hook to. If you only have one on the passenger side, it's a one piece rear. If you have one on the passenger and one on the driver, it's a split.
Old Jun 19, 2007 | 10:53 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the type of brackets in the car for the back upper seat will tell you what will fit in your car
either solid back or split back
only you can answer this, unless you take pics of the back seat wall of your car
good luck
Old Jun 19, 2007 | 09:24 PM
dolphan7's Avatar
Looks like I have both pins, one on each side. So this means I need to buy a split back seat.
And you are saying the bottoms are all split.
Thanks for all your help.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
