Front Passanger Pouch?
Old Jun 23, 2007 | 11:09 PM
89_KITT's Avatar
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
hey i need help fixing my front passanger pouch the dang thing everything falls threw the bottom? i need help do i rip the dash apart and get fix it from the back? help would be nice thanks!
Old Jun 24, 2007 | 01:54 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Front Passanger Pouch?
I'm not sure what you want to do? Do you want to fix the pouch or replace it? If you want to fix it, there are plenty of ways you can. You can be all professional and proper and take it off and get it resewed. Or, if you're not picky about details, just duck tape the hell out of the inside. If you want to replace it, then I believe you can pop it off, but most likely remove the dash panel...
Old Jun 25, 2007 | 11:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yep, they are held onto the dash via a trim screw, IIRC. So it *should* pop off.
I have a spare one if you need it, I think.
Old Jun 26, 2007 | 07:40 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The thing is held on by the same clips that hold the door panels on, just pull that baby off, repair it, buy new clips, and reinstall it.
Old Jun 27, 2007 | 09:55 PM
89_KITT's Avatar
Engine: 2.8L V6
Axle/Gears: factory
you guys are gods ! thanks its jus the bottom of it like half of it is still attached on the bottom but one side isnt attached. and the 2 sides are attached. so im gonna try and fix it cuz i really like the pouch where can i find new clips by the way?
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
MantyZ28
Oct 2, 2015 10:09 AM
88gta3508
Aug 29, 2015 08:25 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
