Installing Door Panels
Old Jun 25, 2007 | 05:32 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
I just got a nice set of black leather door panels, but im not sure how to install them, i know how it goes but im not sure what i do with those circular yellowish plastic caps/clips...do they go into the panel or onto the door??
Thanks!
Old Jun 25, 2007 | 07:53 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Installing Door Panels
both. I believe you're talking about the retainer clips. They hold the door panel to the door
Old Jun 25, 2007 | 08:23 PM
Celticsfan's Avatar
Car: 1985 Trans Am
these: http://www.moderndaymuscle.com/inc/sdetail/1286
which stay in the door and what dont? a bunch of mine are stuck in the door
Old Jun 26, 2007 | 03:50 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
well, what is supposed to happen, is the clips slide into the door panel an then are "pushed" into the holes in the door. If there are some still in your door, pull them out. make sure the clip retainers, for lack of better words, on the back of the door panels arent broken.
Old Jun 26, 2007 | 07:24 AM
Celticsfan's Avatar
Car: 1985 Trans Am
i dont think there are any on the new panels, they might be stuck on the old ones, and if i need some is a junkyard likely to just have a container of these or am i going to have to take them off their?
Old Jun 26, 2007 | 07:35 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just go to Pep Boys or any auto store and buy new ones.
Old Jun 26, 2007 | 09:13 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Well i started to night trying to get to the window felt got most of the top off but how the hell do you get the trianle piece off?
Old Jun 28, 2007 | 11:34 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Axle/Gears: 9 Bolt 2.77
You should get a factory shop manual...comes in VERY handy when taking things apart and putting them back together. Everything is pretty much listed step by step on how to do this kind of stuff.
Old Jun 28, 2007 | 02:04 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
hey while you guys are on the topic, i have a set of door panels from a 87 gta. now on the inside of these there are metal bars that hold the plastic clips in, the metal bars have come apart from the inside of the door panel, is there any adhesive i can use to glue these back to the inside of the door panel so i can put these on my car?
Old Jun 28, 2007 | 08:40 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ya i also like the just learn as you go, ive figured it out, i dont need to take out the triangles, but it looks like the window felt i got from classic, the hole dont line up! i called them so well see....
but a manuel is a very good idea
Old Jun 28, 2007 | 10:46 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, I could never get the top felt/trim piece to align quite right. I just got frustrated one day and bolted them to the door frame from the top...
Old Jun 29, 2007 | 09:31 PM
Celticsfan's Avatar
Car: 1985 Trans Am
what do you mean from the top? I think im just going to drill new holes...
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
