Autometer too high...need gauge advice.
Old Jul 9, 2007 | 04:25 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I gotta 91 RS with a 3.1 V6 so I got the all electric cluster. I was looking at some Equus gauges cause they are priced ok. Thier fuel gauge uses the 0-90 ohms so I can use my factory sending unit with that. The voltmeter is no concern. The oil pressure gauge, I will probably have to use thier sender and get an adapter to fit my factory threads. The tach seems that it might be ok to install with no worries. The speedo is a different matter since thay don't make an electrical one...only mechanical. The temp. gauge should'nt be that bad and I will prob have to use thier sender as well. Any advice on the speedo? I was kinda wanting to keep all the gauges the same from the same manufacturer. I am working with an extra cluster, so I can gut this one and use the face as a template for the new gauges.
Ken
Old Jul 10, 2007 | 06:06 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
Re: Autometer too high...need gauge advice.
It would be very easy to convert to cable, but I'm not sure if your FI and/or torque converter lockup will work right without the VSS. Maybe adapt a cable-driven VSS like they used on the back of pre-90 Camaro clusters?
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
