Is the upper door panel weatherstripping replaceable?
Old Aug 15, 2007 | 05:26 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
The black molded plastic piece on the top of the door panel. Can this piece of weatherstrip be removed and replaced? If so, what is the procedure and where can I purchase new weatherstripping. Or do I have to buy an entire top piece with the weatherstripping attatched.
Old Aug 15, 2007 | 05:58 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Is the upper door panel weatherstripping replaceable?
Check with Hawks, Modern Day Muscle, Classic Industries Camaro, Ecklers Camaro to name a few.
Old Aug 15, 2007 | 05:59 PM
Stevo's Avatar
Car: Pair of 92 Z28s
You have to buy the entire top piece with weatherstripping. Those are pricey too.
Old Aug 15, 2007 | 07:34 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
First of all, your best bet is a search through the jy's. I have found many awsome sets of uppers intact. I have also replaced (new) weather stripping to (old) upper door plastics. You do not need to buy everything new, the procedure for removing the old strip is just to remove the staples from the old weather stripping and figure out a way to reattach the new ones to them. I have a method but it will take too much time to type it, I think I have an old post on how I did it if you search.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
