4th gen door panel in a 3rd gen
Old Sep 14, 2007 | 11:44 AM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
will they fit??
Old Sep 14, 2007 | 12:08 PM
Firebat's Avatar
Re: 4th gen door panel in a 3rd gen
Only with a 4th gen dash. Fit best if you cut the back mounting tabs on the 4th gen panel and massage(aka take a hammer and dremel cutting disc tool to) some portions of the thirdgen inner door.
Old Sep 14, 2007 | 12:41 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Ive seen it done before, Will they fit? Well anything can fit with enough time and effort (and money)
Not for the first time fabricator for sure.
Old Sep 14, 2007 | 12:46 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
ok without the 3rd gen dash in (taken out) it'll fit without prob?
Old Sep 14, 2007 | 06:22 PM
Firebat's Avatar
They should fit without the dash in. The door panels will still have to be trimmed down and all that though.
Old Sep 14, 2007 | 09:28 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Originally Posted by imRICH23
will they fit??
No. Not without a good amount of fabrication and modification of the door.
is your friend. Look for posts by Shr00m.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
