camaro dash and interior buttons
Old Sep 19, 2007 | 02:12 AM
thelusivetoilet's Avatar
so im new to the american car scene. my last car was an 87 acura integra. it was my dd. and i took care of it, i knew everything about that car, and how to do it. but now comes a new challenge , i just bought an 86 camaro z28. and i have no idea what all the buttons do. the mods i know it has is edolbrock headers and a hurst.
now my question is my car has foglights where would that button be seeing as how i cant find it. also my heater seems to be constantly on but the **** seems to be in the off position what could it be?
another question is my horn doesnt work, and the switch for the door locks doesnt work either.
im sorry if my newbness kinda made this whole thread one whole big question
Old Sep 19, 2007 | 07:43 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: camaro dash and interior buttons
Your car is an 86 so the fog light button *should* be mounted under the headlight **** to the left of the steering wheel.
When it comes to your Horns and your door locks, There's a very high probablility that the terminals are simply covered in a light corosion and it's not allowing good contact between the wiring and the contacts. If you disconnect the horn wire and clean the terminal on the horn and the connector than your horn will probably work again. The same is true for the door locks.
That's not to say that the previous owner of the car didn't disable these options by cutting wires or something,......... but try cleaning the terminals and the wiring connectors if everything appears to be hooked up correctly.
The Heater - sounds like the blower motor might have been "hard wired" so it has power all the time. Fixing that issue might take more diagnosis than I have time to write about !
Old Sep 19, 2007 | 07:21 PM
thanks thats really informative. im new to alot of the perks of the car, like the power windows and whatnot. so i should clean the terminals which are under the horn button and under the door lock button?
Old Sep 19, 2007 | 07:50 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
correct clean all contacts. its an 86 so the power lock motor might be pretty worn out too. does it do anything? try to click try to move? if by chance your blower motor is hard wired to a constant run, the easiest way to make it a cool option would be find the two wires running it, splice them into wires that run into your center counsel and hook it up to a switch..or make it a hidden switch. you control heat. pretty neat
Old Sep 19, 2007 | 09:41 PM
DillonRager's Avatar
also check your fuses on the horn and locks my fuses were blown could be easier than you think.
Old Sep 19, 2007 | 10:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That same fuse also affects the dome light, cigarette lighter, underhood light. Can't remember what else if anything.
Old Sep 20, 2007 | 03:57 PM
John in RI's Avatar
Yes - BUT it's more likey the parts that are exposed to the outside of the car will be corroded first. I'd try the plug AT the Horn and the plugs AT the door lock motors first. Since the door panel will be off take the time to check the lock switches and use Lithium grease the lock rods and door latch as well while your in there !!!
Old Sep 21, 2007 | 11:56 PM
the power lock button doesnt do anything
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 14, 2015 08:25 PM
Vintageracer
Aug 11, 2015 08:13 PM
