AC Question
Old Nov 10, 2007 | 08:59 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
AC Question
I have already deleted the AC crap from under the hood. I am pulling my dash out (have to replace heater core) what crap can I pull out/cut out that will further my AC delete project but keep my heater installed?
is there REALLY an AC delete dash out there with out the central vents? pics?
Old Nov 10, 2007 | 11:34 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: AC Question
Never heard of one that deletes the center vents, but you can get a heater only HVAC control panel. Now when you say everything, you've got the compressor, evaporator, condensor, accumulator and orifice tube out? and you've replaced the evaporator with a heater only box, correct? If all of that is not out, then make sure you get the heater only box and control panel from the same car, it's just easier.
Outside of this, the HVAC flapper box (or air direction controller if you must) is the same for heater or non heater. I would preserve the wires if you can. Usually, you can sell the whole AC unit for a fair chunk of cash (if it's complete and functioning), Or if you ever decide to put it back.
Old Nov 11, 2007 | 12:40 PM
C.M.Jones's Avatar
Re: AC Question
yeah I got the controls but stupidly cut the pull wires and the control in my car are vacuum controlled not wire. Is there a way to take the ***** off so I could just switch the front plate
I had to break up the inside box of the doner car to get a bolt out for the engine compartment box (it was stripped) and at the time I didn't think about converting the interior.
I read that the camaro came with block off panels for the vents, but the doner car had vents
Old Nov 11, 2007 | 01:27 PM
ntomsheck's Avatar
Car: 1989 GTA
Re: AC Question
Unfortunately you can't change faceplates. There's a different ammount of swing on the selectors and it would be off. All HVAC controls are vacuum controlled, the vent flaps and the coolant diverter are run by vacuum. The rest (fan speed, relays for AC, etc) are electrical
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
