removing the sfift knob on an 88 iroc w/automatic transmission
Old Nov 13, 2007 | 10:27 AM
88irocautomatic's Avatar
removing the sfift **** on an 88 iroc w/automatic transmission
Hi guys, i'm new to this site so I hope this is the correct way of doing things. My dillema: How do I remove the shifting **** from the shaft on an automatic transmission? I cannot find any screw etc. Does it simply twist off?
Old Nov 13, 2007 | 11:04 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: removing the sfift **** on an 88 iroc w/automatic transmission
there is a metal retainer holding it in that's shaped like a staple. you have to get a small flathead screwdriver under it and pry it out. It's inserted horizontally from the front side of the ****.
Old Nov 13, 2007 | 12:44 PM
have looked under the **** but see no clip.? could the clip be located under the popup center plastic piece and if so how do you remove the plastic piece without breaking it. thanks!
Old Nov 13, 2007 | 01:02 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Check properly, it's on the front side of the shifter, if you have a stock shifter..
Old Nov 13, 2007 | 08:49 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Yep, same on mine. Just on the front of the **** just above the bottom edge, hard to see and feel, but it's there. Pry it out and the **** pulls off.
Old Nov 13, 2007 | 09:14 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
It Helps to pull the shifter to First gear, (Engage the E-Brake First) and look at it from the other side, you'll see a little notch.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
